| Ever since installing leader gears I've been missing or hesitating under full throttle but only after it reaches higher rpm's. Before leader gears I never had issues with 14psi on 91 octane, 17psi on 100 octane, and 21psi on q16. After leader gears it hesitates even with base boost (10psi on 91octane) but only when heavily loaded(full throttle and upper rpm range). My initial thoughts were spark blow out but I haven't touched them and have not had problems pre-leader gears. Perhaps a failing fuel pump or fuel pump controller? My afr stays steady at 11:1 to 11.5:1 while at wot so I don't think that is the issue. Maybe I need to data log fuel pressure to see a dip in pressure? Any chance my z needs to re-tuned? Could the leader gears change the engine load enough to put me in less then ideal cells in the timing and fuel maps?
